Pro-Concept Plus Height Adjustable L-Desk w/ Frosted Glass Door Hutch in White & Deep Grey - Bestar 110897-17
Pro-Concept Plus Height Adjustable L-Desk w/ Frosted Glass Door Hutch in White & Deep Grey - Bestar 110897-17 Pro-Concept Plus is the smart solution for furnishing your workplace. This collection has all the elements to create a modern and personalized office space. Durable 1" commercial grade work surfaces with melamine finish that resist scratches, stains and wear. The electric mechanism allows you to quickly and quietly adjust the height of the table from 28" to 45". The control button is located on the front edge of the work surface for an easy access. The desk features efficient wire management to keep your work surface organized. The pedestal offers two utility drawers and one file drawer with letter/legal filing system. The drawers are on ball-bearing slides for smooth and quiet operation. One lock secures bottom two drawers. The hutch features 2 small and one wide middle compartment behind the frosted glass doors. The hutch has a rubber strip for efficient wire management. The hutch accommodates Letter/Legal size binders. The desk is fully reversible. The desk meets or exceeds ANSI/BIFMA performance standards for durability. Overall dimensions : 71.1" x 71.1" x 70.1". Credenza : 71.1" x 23.5" x 29.7". Height adjustable table : 47.6" x 24" x 28" to 45". 110897-17 Features: This piece is from the Pro-Concept Plus Collection Made in Canada 10 Year Warranty Assembly Required Finish: White & Deep Grey Dimensions: 71.1W x 71.1D x 70.1H Approximate Weight: 416 lbs.
Price: 1189.99
© 2018.
